I bought a new firestick 4k and it want let me download fubo on it so I side download it but it want let play said it not compatible does anyone know how to make it work
What Country is your Amazon and FS registered in? Amazon often has country restrictions for some apps.
The United states it wants let me anything but Netflix
Well if you have an Amazon.com account you should be able to find the fubo apk on tons of sites. Do a google search and when you find one at say apktime then use your Downloader app to download and install.
Have a Amazon account and getting fubo is not a problem firestick 4k the newest one want play it want play you tube either and it on the control fubo is not in app store you have to get through the downloader but when you do when you try to open it firestick want let you
Every app except Netflix when you try to open it it said unavailable and doesn’t open
Ahh ok. I just tried it and it does install but won’t run without Google play services. Let me see if I can find one that plays.
Ok so it can be done. I did it and was able to get to the login screen, but I don’t have an account. Do a Google search for install fubo tv on 4K Max Firestick. Then read and try the methods given. I installed Mouse Toggle and Aptoide and then installed Fubo TV, updated it using Aptoide which I had to enable it to install unknown apps and voila, done.
Ok I will try that and hope it works thanks you for your time
This topic was automatically closed after 6 days. New replies are no longer allowed.
