firestick quit working, I’m using kodi with serin or the crew goes to the last step then I get a no stream available message, anyone know why and can I fix it
I’m using a FS also w the same two builds and working perfect. Wish I could help. All I can say is try deleting and reload.
You’re getting zero streams? Are you using RD? Verify internet connection on the device?
It sounds like the FS is working, but your Kodi addons are not ‘scraping’ any streams.
In many, if not most cases,it’s because Real Debrid hasn’t been properly installed or you’re not currently a subscriber. That would apply forboth The Crew & Seren, though The crew sometimes will show free streams if the settings are set to do so.
In Seren’s case, an outside scrapper must be used, either a4k scraper or Onion in addition to a debrid service.
