Firestick jailbreak without KODI
I used to be able to just use downloader to add APK’s on my Firestick. Specifically Baest TV and Cinema HD or Nova. Those APK’s are all coming up invalid URL. Any ideas to help me out?
Thanks, JP
use unlinked loads apps direct to stick
what is unlinked? Do I access it from downloader?
its an app that you can use to get apps from google it and you can use downloader to get it when you get it let me know and ile give you some codes you can use to get apps
downloader code 234753
I downloaded unlinked. asking for an add new library. I just want to unlock my Beast Tv IPTV, Cinema HD, maybe Nova, Tea TV, or Typhoon apps or something similar.
I am assuming you can no longer connect APK’s directly from downloader like in the past. We need 1 of these “sideloaders”, like Kodi or this app or real debrid.
If you want to email me direct, it is jparyz@yahoo.com. Thanks for your help pirate77!!
type in the code i sent ie its FIRESTICK and it will add library here are some other codes as well lots of apps in them EB2E4A4C and 67664537 each one will add library . and you can still load apk file i use adb link to sideload
what is adb link? and does that sideload direct to the firestick? not as well versed on this stuff as you, but enough to be dangerous, lol
Downloader works perfectly with the firestick to download and install APKs. You just need to enable developer mode by going onto settings>my fire tv> about> and click the name of your device 7 times> back out 1 screen>developer options>enable apps to install 3rd party apps, foe example downloader will be listed if you have it enabled and click on it and enable. Bacl all the way out. On the Sticks be sure to delete your APKs after install as they are no longer needed and just take up space. Also from what I see you are in a learning phase, so my suggestion is to learn all the basics before moving on to ADB Shell which takes a ton of learning, especially getting and entering the commands. troypoint.com will have all the tutorials you need, just use the search on the top right once you’re there.
Have fun and STREAM ON!!!
been doing this for about 3 years, so no technically a newbie. in the past, I simply downloaded the apk from my given apk directions right from downloader and no problems. now I keep getting invalid URL. it seems like they are forcing me to download another “side app” to get my results. any help is appreciated, but it used to be just go to downloader and add the apk with the latest version. type in the https or whatever and then what the cinema (in this case) site said to do. not working that way now. again, not a newbie, but definitely struggling… any help appreciated!
I don’t use CinemaHD just Stremio with OnStream as a backup.
Miki, I’ve been using on stream quite a bit lately. It’s got a very nice clear picture.
Yes it does. Usually plays the best it’s scrapers can find. Good backup.
Does It use real debrid?
Guys, thanks for all the help. Much better success. My daughter will be thrilled. Setting this up for her first apartment. THANK YOU!!!
has unlinked stopped working? Tried to help out my brother in law and could not get unlinked to download. let me know. Thanks, Jeff.
Tried this past weekend to help out my brother in law. Unlinked would not download with the 234753 downloader code. Any suggestions?
