The newest firestick has a few differences in the menu. The option menu for selection(s) when installing add-ons make it difficult. My question is when will Troypoint update the install instructions for the new menu on this firestick? How are any of you handling this?
I was following instructions to install The TV App on Kodi 19.5. All went well until the step Addons/video addons …the TV App was not listed therefore I never got to the next step which is install.
Now when I went back to Kodi settings>File Manager "glive"for the tvapp is listed but I do not know how to either uninstall that or how to proceed to install it.
Can you also clarify what you mean by “installing addons”. Are you referring to sideloading apps or are you referring to installing addons in say Kodi?
I edited the post. I also changed the title. Hopefully, my need is more clear. I have noticed the menu options on the new FS 16gb have options that are not exactly the same choices as the present options when installing the addons on Kodi. The TV App install instruction presently on Troypoint is what I am referring to at this time.
