Question - Can the memory of the Firestick 4K be expanded with an OTG cable and drive if I’m using the Amazon Ethernet Adapter?
You can’t increase the memory (ram) but you can increase the storage.
Sorry - thats what I should have said - storage space, not memory. Thanx
Absolutely you can increase the storage.Troy has a detailed video showing how to do it.Just do a search and you should get several results.
I did it on my FS 4K, but at one point it failed and lost all my data that was stored there and had to restart from scratch. Too bad it wasn’t more reliable and less complicated to expand than the process is now using ADB Shell. Oh well, it is what it is…
The Max is much easier to do than the 4k
This method also works well with .ONN box.
