Firestick 4k Max Kodi
I have VLC but not the others it working fine did you turn off unload apps in settings
Yes, ā€œunload appsā€ was turned off. It all seemed to happen when I move my Cube to a new TV. I’m not too worried about it as the Cube is second fiddle to the Shield.
Ok that’s good but as far as I know Amazon haven’t stopped those apps if they have you should have got a notification from them if you didn’t then probably another reason for apps going
Honestly, I haven’t checked to see if I can re-download them. If I tab on one of them, I then get a message that if I want to re-add them then I need to go to the App store. But I haven’t bothered with them as Kodi, Downloader, Analiti, Dot monitor and SurfShark are still functional.
Def sounds like you haven’t switched automatic offload off i
I think it in ā€œSystemā€ Addons Unknown sources
Have you opted for a different device…other than Firestick? Cut AMZN out.
Oh yes! The Cube is a backup for my Shield Pro. And, even though I’ve not really tapped into my ONN Pro, I have that as a backup also. I am also contemplating picking up a Buzz TV, but not certain which model, yet. That’s why I’m not all that concern that some of the side-loaded stuff is gone on the Cube. Kodi still works on the Cube, so it’s still connected and ready to go.
This is why I got rid of all of my Amazon devices for Kodi. I use nothing but Android devices now and never have a problem. Plus, the Amazon devices usually will die after 2-3 years of use. Everyone I’ve had has died, including the cube. Not so with the android devices.
I hate to inform you that Amazon has block 3rd party app. Therefore, I suggest return your new Firestick once you get the credit, and purchase a Google box such as a ONN plus box from Walmart $29.99. Is better streaming box with larger capacity.
Amazon have not blocked all third party apps most are fine so no need to panic atm
Amazon has not blocked third party apps. They have blocked a handful of apps that use resource sharing (LivenetTV, FlixVision, etc) - I think 5 at last count.
My 4k max 2gen flagged filesync as harmful
welcome
2026 4k not allowing downloader. I tried clicking 7 times to get to developer mode. Didn’t work. Troys video on going to search to type in downloader does not bring up the app. How do I get developer mode? I must not be doing something prior to searching for downloader.
Sounds like you are using the Fire TV Stick Select which doesn’t allow for side-loading or the Downloader app. We do not recommend buying this junk.
