of course lol. Thanks
Right now they have a 4K new fire Stick that you can get about $25 off and only pay $25 and it is close to the speed and specs then the old 4K Max that is missing. I have the 4K older Max first generation and I’ve got to tell you it’s slowed down a lot I keep having to clear the cache. If you do want the first gen 4K Maxx I’m sure they will have it on Woot.com that Amazon owns and sells their old stuff there I’ve even seen old fire TV boxes for sale there for $35 or less. Also wanted to point out that the 4K Max first generation constantly has updates that force your videos to either stop streaming because after I have problems I go into the settings and check for updates and one is there ready for downloading most of the time Amazon should not do this They should at least give you notification that would pop up to tell you there’s an update that needs to be done.
