Fire TV Cube Boots Up To an IPTV app
My Fire TV Cube Boots Up To a IPTV app. It brings up my Fire TV Cube menu first and then goes to the IPTV app which takes some extra time.
Where do I find the setting to control what the Cube boots to?
Once your IPTV app is open, try looking in the settings section of it. It is probably set to launch on boot. You can uncheck that box. If that doesn’t work, there’s another way
Thanks, I’ve give that a try.
