What maintenance is required to keep fire stick 4K running smoothly.
Daily / Weekly / Monthly
I will give you my 2 cents. After every day I clear out any crap accumulated from app testing, including their apks. I use ES FileExplorer to do that. I force close any open apps and go through my entire “manage installed apps” section and force close/clear cache on everything if needed.
Now here is where I do something different than most. My stick is plugged into a power bar with surge protection and I shut the power off, not just turn the stick off. Done.
The only thing I’ll add to what has already been posted, that I also do, is that I shut off my router for about 10-15 minutes monthly.
