Fire HD 10 Tablets
Is there a way to force the onscreen keyboard to appear on any app? I am trying to get this up when I am using Tivimate with hopes of maybe controlling some feature via the directional arrows.
Also, does anyone know of a compatible virtual mouse pad for use with a tablet?
You might want to take a look at the Rii series remotes on Amazon.
Some versions like the Rii 8+ support wireless (2.4ghz), while others support both wireless and bluetooth making them capable of being used with multiple devices at once (although it defaults to wireless when powered off/on).
I have a Rii 8 and it works fine although the manual is almost totally useless.
Some people report issues with the mousepad but personally I’ve found it works well enough.
Check the comments and watch the prices.
Capp
