Is using unlinked the only way to get Cinema HD. When I went to unlinked I only saw Cinema add free and had trouble downloading. Just wondering if someone has an answer. Thanks
Hey stew & welcome…
Downloading in unlinked is a 2 part process…
Clik once & it dwnlds, when its done, clik Again, it will ask to Launch & it will go thru install process…
After install clik a third time to delete apk file (u don’t need it)
You can also get it here.
Cinema HD for Android - APK Download
Hey @stew62 Also a version 2.4.0 Original there…keep scrolling…it’s just before the hulu’s.
Will that work for the fire stick
you will need to side load.
Hi I just finished putting cinema HD on a fire stick thru unlinked with no problem. On another fire stick I tried the same and every time I downloaded unlinked all the linked stayed black and white and would not let me download. Does anybody have a fix.
