Fiber optic problems with iptv
Just switched to a fiber optic provider and my tivimate and iptv smarters will not work. Does anyone know why and what if anything I need to do to fix it?
Were you given a new IP address? Is your iptv supplier ip address locked? It maybe something else but when 2 different apps, that are just iptv players, have the same issue I suspect it’s supplier side.
Are you using a VPN? If you are make sure country is set to what you used originally when it was working.
check you havent got websafe on in router settings
As Nvidia Miki suggested, I would first contact your iptv providers. It could be something as simple an ip lock.
If you want, you can search the threads here for a m3u for Pluto, Samsung, etc… and test it out on your tivimate and iptv smarters players and see what happens. If they play, then it is not a player issue.
Make Sure ISP firewall is turn off their router. Example ATT Fiber
love the moniker for @Miki you are always on the ball :crazy_face:
I’m surprised that a Mod hasn’t commented…
Please don’t mention any unverified IPTV services!
I have took care of it twice already. Thanks for the flags, please use them as soon as you can when something like that happens in case i miss it.
Nvidia Mik sounds more gangster, but he goes by Miki. I was thinking Miki “The Shield” might work, but then the federales might come knockin on his door. :policeman:
