Cannot load Fen. got the following message "The dependency on xbmc.python version 3.0.0 could not be satisfied. I am installing on an android TV box H96 Max OS Android 12
What version of Kodi do you have? An older version?
Probably should follow the guides. You are using a older version.
I followed the Troypoint guide. I am using Nexus 20.1
Did you first install the repository for the Fen addon from here? https://tikipeter.github.io/
Since I hadn’t used kodi in awhile, after reading Troys newsletter this am I decided to check out fen…all went well. I stayed stock kodi 21.2 and installed fen as per TP and no issues and it looks nice. I might keep it until it dies
Hello @TonyG I think I’ve seen this problem before and I had to uninstall/reinstall Kodi. Also, make sure that you are using the most recent stable release.
Data file corruption error. As Troy said, usually easiest to just clear app data and reconfigure everything. I try to do monthly backups of my build in case stuff like this happens.
Yes I did install the Fen addon from above
