I have recently installed Fen and like it very much. In my opinion it is one of the best Kodi add-ons available. One question, where are the downloads stored? I downloaded a movie as a test. The download went okay and appears in Fen in the downloads section. However, when I load a file manager and look around for that file, I cannot find it anywhere. So where is the file actually stored so that I can copy it, delete it, etc?
Hi JimInWoodstock
Not sure where the default download folder lies but you can set it up from settings in the main Fen menu
I use /storage/emulated/0 as that is the default folder for most APKs
Click on Settings in main menu
Click SETTINGS:Fen
Scroll along to Downloads
Move down to Movies Directory ( this shows current download directory, if set up )
Click on Movies Directory
Click on 2 little dots at top until you see External storage
Click on External storage
Move down to Download and click
Move to right and Click OK
Go back to Downloads and carry out the same process for TV Shows Directory
Click on OK at bottom to complete settings
That’s it you can now use your file manager to access your Movies and TV Shows in the download folder
Hope that helps you out
Cheers
