Hi,
I have added Fen to Kodi twice on my fire stick because the first time after every search I received a ‘no results’ response. Upon deleting it and re-entering all of the addon info from Troy’s guide, I once again tried to find items and received ‘no results’ each time. I have Real Debrid loaded through Fen. Any suggestions? Thanks!
Go to your RD acct and make sure your sub hasn’t expired. Lastly, go into FEN settings and check everything to make sure items are properly selected . ![]()
Was doing the same for me.
Went back to settings
Coco scrappers(or something like that) default providers
And also enable all providers
Then OK
Didn’t see it do anything but after that it worked
Don’t know why but……
I had the same problem. I uninstalled it.
I had the same problem so I uninstalled it.
You have to exit Kodi after installing it and then open open Kodi again. That worked for me.
Installed FEN tonight. Pretty decent App and with RD it returned a great deal of content. Like the original poster, at I didn’t get any links at first. Went into settings and enabled all providers etc and it worked a treat.
Thank you for the advice and the speedy reply. RD is up to date so I will check to other items in the Settings.
Thanks so much; I will try that.
Thanks, Lar. I was looking for others on the site to see if I was the only one experiencing problems. When I didn’t see any concern, I decided to post and I am very glad I did since you and the other responders have given me bothe vindication for my predicament as well as maybe a way out of the rabbit hole.
I believe I did that each time since it is a common suggestion which I have seen in posts for other addons. Thanks for the suggestion!
Thanks so much for the vindication and the suggestions which amplify which previous posters have suggested. This is a great forum.
Thank you for these recommendations. I have not had any problems with the real debrid account prior to this with respect to authorizations but it sounds like a worthwhile thing to do.
This worked for me too.
