Extreme HD IPTV Installation on Samsung Smart TV
I just came across instructions from Extreme HD on how to install their app directly on a Samsung Smart TV (https://xtremehdiptv.io/us/how-to-install-xtreme-hd-iptv-on-samsung-smart-tv/). While it seems much simpler than installing the app on a Firestick, I would think it would leave one pretty “wide open” in terms of security, from both your ISP and Extreme HD. But, as Frank Zappa would say, “I may be totally wrong…”.
Any thoughts?!
The app is NOT owned or modified by Xtreme HD IPTV
  • the link says you download IPTV Smarters Pro app from Samsung app store / no sideloading
  • It’s an IPTV media app with no service
Link to IPTV Smarters website - available for any device
You can link a vpn service to work within the app
