Looks like I originally posted this in the wrong section.
Hope it’s right now.
Hi
Ive put on the above build on Kodi 20.2, i’ll say at this point I have waited years for an upto date default skin and it’s been worth the wait I absolutely love this new skin.
Now the down side I first installed it on a FS max easyish as a test installed ok, but it had a problem i’ll get to in a minute.
So with that aside I installed Estaury Flix 1.1on my main device a Shield Tube and what I keep getting is what ever topic I choose gets highlighted and it just keeps pulsing and the spinner starts up as well.
It’s driving me nuts, anybody knew anything about whats causing it? or a cure.
Update
Whilst i’ve been waiting for a reply, i’ve yet again uninstalled kodi.
Searched around and found the FENtastic skin.
I’ve installed that plus the addons I use.
Works as smooth as a babies proverbial.
Hey. Im not sure exactly what the problem was but i installed onto my phone to test out. Everything seems to be working fine, i like it better than the fen build.
Hi
thanks for the reply, all I can say as in my original post mate.
Anything that is highlighted just keeps pulsing and the spinner starts this happens for many minutes I cannot do anything and just hope it does stop.
Then when it does I select the next option whatever it is the the whole procedure starts again, it takes so long I never get the installation to work.
Thank you.
I’ve got it setup, but only by loading everything singularly.
I downloaded the FENtastic skin, set it up.
Added Seren, now i’m into Umbrella with Cocoscrapers added that as well.
Then the Sports Apps
Rising-Tides
The Loop
Daddy live
It all works perfectly.
But I still don’t know what the problem is that it wont run correctly with the EstuaryFlix 1.1 build.
Hey. Tried out on my shield pro. Was running ok but.didnt feel snappy, crashed a few times. I did notice on a few menu items as you scroll down on the left, on the right was big spinning circles.
I would recommmend the xlite build that is pretty fast and doesnt crash.
Let me know hownya get on.
Also once ya install a build go to spanner icon>account manager>real-debrid>authorize. And it will setup debrid for all addons. Just make sure ya wait for it to sync the addons. Im sure when you install new addons ya just need to press sync addons to get the new addons linked to debrid.
Thanks bruv
But with the greatest respect I know all that, and have done that and more.
Sadly still don’t solve the problem, or even make it any better.
