ESPN+ and Big Ten Plus content
Are there any APKs or add on’s that have the ESPN+ and Big Ten Plus content on them?
Thanks.
Sportsfire has the Big 10, ESPN and ESPN2, but not ESPN+
Yeah, I am running SportsFire now. I have never seen any of the PLUS content on there for Big Ten or ESPN.
Was hoping someone had a solution for that.
I haven’t seen the + on any free apps.
Yeah, that’s what I was wondering. :slightly_frowning_face: Does anyone know any free IPTV service that may have these?
None. My 3 IPTV subs have 400 ESPN+ channels each.
You can check these.
Ok, thanks. No luck with Big Ten plus on your IPTV subs?
Is Big10 plus different than Big10 Network?
My IPTV Service has all the Big 10+ channels however it is invite only and at least for now they are not taking on new subs
Yup different channels. Normally the marquee game of the week for that conference will be shown on the regular one (if not on Fox, CBS, ABC etc) SEC has the same thing as well
If you have TiviMate and a sub or 2 or 3 etc., the best way I’ve found to locate those games that are played on the streaming + channels is…go to the search on the far left side column of TiviMate and type in the name of one of the teams playing, like Tulane or Kansas or whatever. Then the results will show you if you have a channel playing that game.
As I mentioned, each of my 3 subs have 400 ESPN+ channels.
Right, mine too. And most of them, or a lot of them, won’t show information in the epg section so you don’t know what’s playing. Saves a bunch of time just using the search option.
Oh yes agreed, but my sub has the content posted in their discord. It’s actually not a channel I bother with as it rarely has any content that I watch.
All 400 ESPN + channels posted? Woah. We have to use it quite a bit because most of the NCAA women’s basketball games are played on it.
I’ve never seen all 400 channels with content at the same time. I can’t honestly say how many daily events are posted, as I mentioned, it isn’t anything I usually watch. There is a daily list of events and their corresponding channels.
Hi, Streamfire apk , similar to Sportsfire, has Big Ten, and Espn.
Quality is not very high…
I have the Alibaba £15.80 A YEAR subscription with 15,000+ channels which I run on
IPTV SMARTERS.
I’ve had the subscription since December 2023 and It’s nearly renewal time.
All in all, it’s the best 15 quid I’ve ever spent.
I’ve had a couple of minor glitches, but as soon as I contacted them, it was fixed straight away.
They have all the channels you require.
Hope this helps.
Cannot recommend it enough
Sports Hub on kodi 21 under sports you will find it there
welcome
