Error with Orion addon
I’ve been using Stremio with Torrentio and Orion for several months now. Recently, however, I’ve been getting an error on Orion stream: “Your daily limit has been reached. Please wait 24 hours or upgrade your account”. I’m not using any Orion streams so I’m not sure how a daily limit has been exceeded. Anybody know what’s going on?
Any time orion pulls a link it will use your 10 daily.
I’ve been getting it as well gor about 2 weeks. Shows up on some vids but not on other. I pretty much use RD+ all the time Orion is just a rare use as a backup.
I can look into it further when i have time as i have a yearly sub and 10k daily links. They where doing offf and on maintenence and general improvements
I suspect it was maintenance D. Usually happened between 7 and 9 pm local time.
All times of the day, all videos. I’ve uninstalled Orion, Torrentio is working fine.
Yes, i get the same on a few movies/ series i want to watch, despite not using Stremio for a couple of days.
I also get, " error incorrect Api key".
But again only on a few movies/tv series.
Checked Api key on computer all good. Tried again, same issue with “error incorrect Api key”
Really bewildering.
Its not, orion and rd require authorization. Use torrentio links or free links.
Orion and rd are working fine.
Well, as a followup to yesterdays issues with Stremio (Real Debrid?), having reset everything up I reinstalled Orion, added the API key, tried it out and am getting pretty much zero streams/sources. Those streams with one or two sources (real debrid - no sources on streams without RD) say “playback error, please try again”.
Am I doing something wrong?
Possibly but there vary well could be issues with orion. As rd is working just use rd links or free links from torrentio.
Cant test till I’m home and tjat wont be till tomorrow.
I was trying to point out, that on some movies/ tv shows, i only get 2 links and they are orion links only…One stating invalid api key and one stating daily stream exceeded or words to that effect.
But no other streams including AD, torrentio or free streams.
But even on streams that i do get from Torrentio or AD, there is always the last link that states " ERROR invalid API key.
I hope that clarifies my original reply to the OP.
Regards
Fully understand. I will try to test this can’t till tomorrow so everyone is my wyes and ears please report back
I have this problem with Orion and Stremio too, and how would I set Orion up with Real Debrid?:thinking:
That requires you to go into your orion account and authorize rd in there. Then configure orion in stremio.
