I have one channel in my favorites i like to watch, but now everytime i click on it , it will buffer and then say error code 403, only channel it does this, any suggestions?
Is that the "forbidden " code? I believe it is. This is a tough one as the server has determined you don’t have the proper creds. So what you can try is to log out of your Service, clear the cache, try logging back in. Another way is to uninstall your IPTV service, clear cache, reinstall it and try again.
Ok thanks, i will give it a shot
If what Miki suggested doesn’t clear it up…put in a service request with your iptv sub.
Contact the company you’re subscribing to. They should have tech support. Good luck ![]()
Did you have any luck?
Yea tried what you said last night, it seems to taken care of it for now, thanks Miki appreciate it!
so did it work? i’m following
Yep, worked well after I did the things Miki told me to try.
I have a unique problem that is driving me crazy and I suspect it is my IPTV provider. The provider has two services, one full and one streamed down. The full one just gives me a 403 error code on every channel using tivimate and on sparkle it will not even load the playlist. I have tried both surfshark and IPvanish and get the same results even trying multiple cities or countries. I have tried without a vpn and get the same result. But I have it loaded on my phone with IMplayer and after going back and forth with the provider about the intitial problem, it at least works on my phone. Any clue on what it might be? Or pm me with a good provider you use as it looks like after 5plus years it is time to move on.
