Earlier Advice that Cinema HD APK Forced To Close?
Hi Troy,
Just a question - Is CINEMA HD back ? I removed it because of the previous advice that it had been shut down, Pls advise. It was the best APK i ever used. Trevor
I highly recommend if you plan on using it, that you get it from the genuine site. Someone else apparently took it over and it seems fine again. For how long? Nobody knows. It could go away again or could be back for longer. If you pair it with Surfshark it gives you an ad-free experience.
