This is a wonderful addon always updated on top of it . But yesterday update completely put it in stop at scrapping and resolving and that was one of the updates that he did anybody has an answer I’d appreciate it like I said this is a very well constructed add-on I know he’ll probably get on top of it but I just wanted to put it out there that I know I’m not the only one that’s experience in this I don’t use it in the build thanks for any help
sounds like this was likely due to the change in the scraper dialog to include the debrid check.
it’s 100% working for me. without details the only recommendation I have is to reset the defaults for that category only, select “ok” and try again.
what are your settings for for the scraper dialog:
- source select/auto play?
- progress dialog foreground/background?
- any “kodi.log” file I can look at?
- debrid provider?
Thanks for getting back exactly what ur saying I tiredboth auto n source select I tried foregoing and background. I’m going to try the default thanks again
I’ll send copy of Kodi log but it just starts scrapping then says no stream checking cache then stops I try to cancel say canceling but freezes I really do appreciate getting back to me I really enjoyed this addon
if you use Alldebrid there was an issue. a new version has been pushed.
Kodifitzwell code on downloader doesn’t give the zip file anymore. Therefore can’t install any add ons like Dradis.
Yeah I found it thanks again
