Just a question for the family, is there a way to get downloader or an equal on an android phone such as a Samsung S10e ?
Yes, the rapid app installer works as a downloader.
I have downloader installed on my Samsung Galaxy S21+. There are a number of APK installers you can use, but as TP-DRACOO mentioned, Troy’s RAI also works perfectly and has a ton of uses other than simply installing apps. Like tutorials.
downloader is in the app store,it’s on my samsung phove,also RAI is also on my phone
The rai works the same as the downloader… just so everyone knows, however as mentioned above you can put this on mobile units
how can i get downloaderon my galaxy z flip3 5 g
dumb question
what is RAI?
Rapid App Installer
troypoint.com/tpapp
Put that in your downloader and you’ll get it.
thank you for the good advice.
