📌 Downloader Not Working On Fire TV or Android TV/Google TV? Use These Fixes!
Is you’re having problems with Downloader, please watch this video from beginning to end.
:wrapped_gift: Free Ultimate Stremio Setup Video
:locked: Surfshark VPN TROYPOINT Discount
Just updated Downloader to version 2.3 last night and it is working well.
Hey @sim_bill is that 2.3 or 2.0.3 I Was looking for 2.3 but no luck.
2.3 I think.
I double checked Mr. @sim_bill and it definately is 2.0.3 on all my devices and I haven’t found any 2.3 ones to download. Have a great buffer free weekend, spring has finally come here. Hope you and yours are well. Stay safe.
Yup, 2.0.3 latest update for my onn 4k pro, and 2.0.1 for my android phone
:+1:
Thanks for straightening that out Miki. You are our Sherlock Holmes for all things technical along with Troy. Enjoy your weekend.
Sherlock? Not me my friend. I know you’re on top of things and thought you may have an update I haven’t seen, so I thought I’d ask. All good. Have a buffer free weekend.
Hi :waving_hand:t3: I am new here! I am very thankful I found this community! So much valuable information! I have been using streaming boxes since 2018 or 2019. Recently decided to try some new ones. I got the Tanix T5 thinking it would work like my former omes. Big nope! Cut to the chase: the first time I downloaded Downloader from Play Store. It worked great! As soon as I reboot my device and try to use Downloader it crashes. i checked all the settings, I uninstalled and reinstalled and it just keeps crashing. I decided to do factory reset and reinstalled and worked great again until reboot. I don’t want to factory reset again. Please help!
Maybe a setting like ADB needing to be on. Don’t know that particular box.
Downloader blocks my RBTV I’ve had to uninstall it
Downloader updated on my phone and it’s not working anymore
play protect turned off and unknown sources enabled
Did I miss something
Is there an answer to those systems getting parsing errors?
Parsing error usually means that you are trying to use an app that isn’t compatible with the streaming device.
It’s a 2nd generation firestick. Do I need to upgrade to a 4k max?
Apologies, but I’m a senior citizen therefore not very tech minded.
Thanks
Tubi mod works flawless on FireStick! Every movie and show with no commercials!
Now I just got ONN Box Google. How can I get Tubi on there?
I installed a few apps OnStream and projectivity launcher but I really love tubi and I want it on my Google onn box.
Thank you
Welcome gif
Thank you! I tried downloading a few and they’d be stuck in “connecting” status. After watching the video it was Surfshark that I needed to disable. Phew!
