I just received your latest Insider. Downloader was an easy install on firetvstick 4k. But, the play store and also AFTV said it’s not compatible with an Android box, just an Android tv. Previously I had it installed on both my Android boxes. Is there a work around? Thanks
just sideload it, you can find it over at apkpure.
Downloader APK for Android Download
Thanks. Right after I put the message up, I realized to give that a try.
