I’ve downloaded and installed JioPages to my ONN device and it works fine. However, I have two icons on my desktop for JioPages. If I try and delete one both are removed. I’m wondering if anyone else has this problem?
Try downloading an apk from a different website. Personally, I used to have JIOPages and found it to alright but too glitchy for me. I use TVBro now and it seems to work okay.
I just downloaded TVBro and tried it out. It works fine so I’m going to get rid of Jio.
Thanks
jio went downhill just after their launch
Hi Powerfader,
What default search engine do you use in TV Bro? I downloaded and will try it out more tomorrow.
I think it works at its best (maybe just me) …with duck as the engine and user agent set as firefox tablet
I use google chrome. TV Bro pages was loading very slow for me yesterday. Going to test out more today.
Ok I just deleted Jio (both copies) and went to TVBro. Works great. Thanks for everyone’s input. Mods you can close this thread. Problem solved.
