DorIPTV Review: Over 23K Live Channels for Under $7/Month
Originally published at: DorIPTV Review: Over 23K Live Channels for Under $7/Month
This review of DorIPTV covers everything you need to know about this live TV service including channels, VOD, pricing, setup, legality, safety, and more. DorIPTV is a service offering more than 23K live channels, thousands of video on demand (VOD) titles, and more for under $7/month A subscription to this provider also comes with premium…
I haven’t seen anything addressing (it may be out there) the difference between pricing by device vs. connections. I have 4 TV’s in my house and if I would use a provider that sells it’s product by device and not connection it has always come out more expensive by device on the providers I’ve looked at. A big point for me too is 2 of my TV’S are used quite a lot, but the other 2 aren’t. So that means I have to pay for a device on the less used TV’s rather having a connection available to us then.
Because this supplier provides login details using an M3U URL or Xtream Codes API credentials - you can use any compatible IPTV app.
My understanding after reading the review / website is that, you can install IPTV app on multiple devices and with a one device plan - you can use it on any of your device but must not use multiple devices at the same time.
With a 2 device plan - you can connect any 2 devices at the same time etc.
For your 4 tv home, how likely are you to use all at the same time?
I’ll try that out. I only tried it once before with another supplier and it did not work. If you added it on another device it would detect that you had it installed on a previous device and would not authorize the device.
that is very uncommon. Never had any do that to me and have used and tested many.
I guess this still would require the use of a VPN?
Does DOR IPTV offer catch-up channels?
This is my concern as I’d need it on two devices, but only use one at a time. Had anybody tested DorIPTV on other devices with one connection?
Noticed this with several - pick monthly plan to really test it
They only offer 3 months… with 7 day money back guarantee😃… has anybody got their money back with this?
Customer service is rude and unprofessional. The free trial is a lure to bring people in. They should remove it from the free trial.offer from their website. Buyer beware
I just can’t resist… Don’t let the the Dor hit ya in the…
:sob::sob::sob::sob::sob:. Good one​:+1:t6:
Just curious - is it possible to use TiviMate with DorIPTV?
TiViMate is an IPTV player. So as long as your credentials are Xtream codes or m3u or Stalker Portal you are G2G
Does Doriptv offer catch-up?
Probably not…or Mustard either!! :crazy_face:
Had this for a couple weeks now. Haven’t had any issue with buffering. OTOH the EPG is really lacking. My main service has a full EPG and I thought it and my other EPG’s would fill in the blanks. Unfortunately not. If I keep the service, which as I said doesn’t buffer and is stable I will go through the channels I watch and assign an an EPG to use.
