Running into ads on Bee and F+. Any thoughts please. I have nine months left on IP subscription.
Can I have IP Vanish and Surfshark at same time.
If it doesn’t, try Blockada - that gets rid of most of them.
I’m fairly certain that IPVanish does not have an ad blocker. I’m fairly certain that you can have as many VPN’s as you want as long as you have the space on your device.
Several years ago I tried BeeTV but it was inundated with ads so I dumped it.
Thanks, another issue I have to address… expanding space on firestick. At eighty my brain power is not what it used to be.
pophott,
You are doing just fine. As far as adding memory on a Fire Stick, Troy, I believe has tutorial on adding an external drive. He also shows you how to move stuff over to the drive. That stuff would be nothing that is burned into the Fire system. Such as all the stuff most folks don’t want or like.
I will try and find that tutorial and post the link here.
Here ya go, my friend.
