So far so good. Only 2 days. I will provide an update next week. I think Tim’s recommendation really did the trick. I’m quite flabbergasted to say the least.
I must have changed a setting in this app, I usually get a email with replies, I didn’t for this.
I am sure you now understand why I said it looks like a scam and it does, I am really glad it was helpful, truthfully I almost didn’t make that post and I really wish they had put more feedback as it runs. Always glad when I can help. Thanks
I haven’t had any issues since running that crazy little utility. Thanks again, Tim!
I wish they had it for the Shield.
Try it, if it’s Android it should work.
Why not simply go into WiFi settings and toggle it off then wait for a minute or so and toggle it back on? Or am I missing something?
@Timwort, I download the app and it appears to be working fine on my Shield. Thanks for the tip.
