I want to add an addon to the diggz xeon build… namely the ivue addon. I went to addons and added it and it installed it, but i can’t find it anwhere. Any help?
Recently my diggz xenon went haywire lost it …I had Superman build on another firestick but liked the ease of Diggz so kept it on other firestick …but had to reboot KODI install KODI with Superman build from troypoint tool box…not as good but has many add ones but require DB account on most …current TV shows hard to download but movies seem okay…
xeon has a lot of addons, takes up a lot of space, runs slow on firestick… but works like a champ on those $20 onn walmart boxes. i learn about new addons and features it seems everytime i use it… but for the family and friends… it does karaoke, movies, ppv, all sports, and use to have the ivue tv guide. using the xeon build is how i learned about the ivue addon. maybe they will update and put it back on there.
Does the Karaoke addon work in xeon? I’m trying to find a working karaoke addon.
karoke is great in xeon. if just want a karoke machine, you can install the addon by itselff. called kodi karoke. i am not sure if we post links. pm me if you need link
Hi, thanks for your help awhile back… the karaoke addon stop working for me. Do you know if it’s still works on your end? Thanks.
