Diggz Xenon URL's not working 11 Jan 2023
As of 11 Jan 2023 I can’t find any of the Diggz links working. I updated my Kodi to 19.4 the other day and when I went in to reinstall Diggz link I get the “Cannot connect” message. Before you tell me that I put the different links in wrong. I did it via cut and paste on all the ones that are out on the web and none of the links work.
So now what is person to do?
Did you try https://diggz1.me/diggzrepo? That was the latest that I have used successfully.
Yes I have tried that one as well. I try it everyday for the last week plus the others I have found online when doing research.
Any other ideas?
(post deleted by author)
See if this will get you there, direct link into the repo…https://diggz1.me/Repo/_repo/
Diggz1
Diggz2
Dijpgggz3
di.jpgggz4
Diggz5
I tried it and here are the pictures of what happened. Any other ideas I can try. Would love to get this build back.
First of all, you don’t have AT&T Fiber as your internet provider do you? I heard they recently blocked diggz url. If not, you see where you’ve got install from zip file in the last picture? Can you download something using Downloader and then save it to your external drive and then install by zip into Kodi? If you want to try that I’ll give you the url for the program chef zip file.
I do have AT&T but not their fiber because its not in my area. I have their Internet 50 Plan. I also have my Express VPN installed on the Firestick and its on all the time. I make sure every time before I open Kodi that my VPN is connected.
Yes, send me whatever you think I can use to get Diggz back on my Firestick. I have never done it that way before so I will go research and lean how.
Thank you for all your help on this.
Here’s a short link for the plugin.program.chef19 addon, it is the one you use to install builds: https://tinyurl.com/diggzchef
Type the url into Downloader, save that file. Then use the install by zip option in your Kodi, browse to your external drive folder and locate and click on this file you just downloaded. Also you may first want to test this https://diggz1.me/diggzrepo in a browser to see if AT&T is blocking you.
One other thought, have you ever tried connecting to diggz repo without your VPN on to see if that works?
Wanted to let you know that I got it back onto my Firestick. I did your second option, I disconnected
my VPN long enough for the Diggz URL to load then I was able to get what I needed to download it.
If anyone else runs into this problem it might also be there VPN or a combination of VPN and AT&T internet.
Thank you for taking the time to help me and I so glad that it is working again.
Glad you got it working again. And thank you for coming back to let us know that you did. :slightly_smiling_face:
Just upgraded to Kodi Nexus 20 and installed Diggz Nexus 9.5 build.
Used url http://diggz1.me/diggzrepo with no issues.
Well if you disconnected your vpn and it installed its not your isp blocking it. Sounds like the vpn was. I dont believed at&t is doing that, if so it would be a whole lot of other addons and such
