Diggz xenon not working?
I got a message yesterday that a new version of diggz was available, so I allowed the update. Since then kodi will not finish loading once I click anything really. The intro then freeze. I’m currently running 20.2 and it operated perfectly before the diggz update. Should i wipe the data and do a fresh start?
i have had some kodi crashes, and i find that usually when i have a kodi crash… its a low memory on the device issue. free up some space. i also always uninstall and reinstall kodi and xeon build. clean install of kodi always after an update. don’t have to, but less issues
Thank you dg, I will do the same. :grinning:
I attempted to install Diggz new build and had a problem. The install zip file seemed to download but when I went to the Diggz Repository I get an error message saying “Could not connect to Repository”. Anyone know what is going on. I’ve been installing Builds for a few years now.
I get some errors installing diggz sometimes. like just recently they made a new pop up screen you need to click ok on after the dowlnload of the build. the most important thing is be patient on the install. see what messages pop up before you back out. and after the build installs… let kodi run like 10-15 minutes before you run anything to let the updates install first… or crash city
Thank you for the advice. It seemed to be the problem and I wasn’t being patient.
My Diggz has been also crashing after starting it up . when I click on something it crashes . I have a TG of storage .
If you don’t shut kodi down properly, like just hit the home button on your remote to get out of kodi… then go back later and run kodi again, without force closing the app in settings… sometimes it will launch a second version (or something LOL) and the only fix is a complete uninstall and reinstall of kodi and diggz build
Is this currently down? I’m following install instructions but no joy. Thanks
