Download went perfect, but no sound? What do I do? I tried rebooting, re downloading and nothing?
Welcome to our community!!
Kinda need more info. What devices is the build on? What steps have you taken?
Have when you get no sound on kodi is it just with kodi everything ends works? Are you using kodia built in player?
Is your device hooked up to the TV or is it hooked up a sound system? Have you tried other links of the same show? Are you getting errors come up?
Have you tried a search?
Firestick, no sound when using build Xenon.
Tv sounds works fine. Sorry new to this not sure what else to do. I went into kodi settings and audio shows it’s there.
Read the guide posted above.
Click settings change your settings to expert or advanced make sure audio passthrough is on and the volume bar is all the way to the right in audio settings.
Tried the link you sent. Still nothing.
I will Un install and re install and see. Works fine on my other firestick I just downloaded build on.
Did take me almost 3 hours to download on my other firestick thou.
