Do you need to update Diggz Xenon Matrix? If so how do you do it?
They’ll notify us when there’s an update. I’ve been on it all weekend. No updates
The short answer is no. Having said that, Diggz will notify you in the app that there is an update. The designer has set up Diggz to auto- update, but you can also go in and manually check and do it yourself if you want to.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
