Diggz xenon matrix upgrade
Hi @zemelya
Changing the skin won’t help.
To get rid of the build, you will need to uninstall and delete the build completely off your device.
Then go back into Kodi and download and install each add-on separately.
So, uninstalling wizard will remove even all repos that came with it?
Hi @zemelya
So, just uninstalling the wizard will not delete everything but leave the add-ons, it doesn’t work like that.
You will have to delete the entire Kodi build you are using off your device. This requires uninstalling Kodi.
Then once you completely delete Kodi, reinstall Kodi, but this time download and install only the add-ons you want to use.
Yo, we are on kodi 19.3 n Diggz Xenon 7.1
