Diggz Xenon Kodi build problem
I purchased 5 MeCool K-3 Android devices; 1 for me and my 4 daughters. I installed Kodi 19.0 and the Diggz Xenon build on each device, all running IPVanish with a Real-Debrid account. The Xenon build has been working great for months for my daughters, but it will not work for me.
When I perform a fresh Xenon build, it works great; - for a few days. After a few days, everything I select goes into a waiting state and hangs there. I perform a fresh Xenon installation, and the same thing happens, over & over.
I install the Xenon build exactly the same as I did for my daughters. The only difference is they live in different places with different ISPs and different internet providers. I can load other Kodi add-ons like The Crew, The Boys, Shadow, etc,- and they all work fine.
I can live without the Xenon build, but I simply do not understand why it does not work.
Last small question. Is there a way to select the VLC player in Kodie, in order to play movies that use the Xvid codex, or is that even a good idea?
Hi @jpilson2
First don’t try the xvid codec, it’s usually a movie that hasn’t been released and someone most likely recorded in some dubious fashion. Give it a week or 2 then try.
As far as Xenon, may try your VPN set its location to someplace else and use the Best Available in that location.
Worth a shot.
Why can I download the current XENON Build for my fs? It only gives me the option for Maddux - Kidz- Version 1.0 when I go to Chef Nexus Wizard.
You’re going to need Omega. Troy warned us about this a few days ago -
It is unavailable on the Kodi 21 build. I have tried 5 times.
Use https://tinyurl.com/diggz123 as the source to add for zip file.
When I get to installing the program add-on-> Chef Omega Wizard, it pops up with an issue with script.module.certifi dependency. I followed Troy’s steps, has anyone run into this? Are they still having issues with the build url?
I know what you are going to ask, Kodi 21.1 from Troy’s toolbox, turned VPN on and off. Using URL you posted right above this post.
I havent seen that yet. Just tested on my phone and i didnt get the message.
Did the chef wizard load and ask if you want to install a build?
If not maybe maybe try to install from repo again.
I tried it 3 times, all different ways and it kept saying that. I just tried and it went through, like the dependencies totally changed. I have installed lots of builds for fun, and never ran into that. Thanks for the help, sorry to waste time posting, but I was confused lol.
No worries. The repo might be over loaded at times. I posted the new url here the other day and it has gotten a lot of clicks. Someone posted a new YT video yesterday too now that the url changed.
