Today I updated my ONN to Kodi 21 Omega from the TROYPOINT Toolbox and left Xexon plus v2.4 installed. After opening kodi and waiting for add-on migration, a “setup wizard” window pops up to configure setting for the new omega wizard to download. Once done, a new window for the Chief Omega Wizard pops up to download a build. Easy process and decent migration of settings; had to reinstall Seren and resync Debrid account. Working good.
What URL FOR DOWNLOAD IS ?
On my 3.0 i have noticed that my favorites don’t work. I’ve tried moving movies to Watch later, but they don’t move to favorites. Any advice would be helpful.
Ok. Just curious how you moved your movies to watch later.
Depending where you save them may be the problem.
If you long press over a movie you should be able to save to favorites from there.
I did the Kodi 21 upgrade and found a unworkable flaw. I’m a free user and d/l my movies & shows to my library. The flaw lies in where when watching TV shows with shuffle enabled it plays the same pattern (example series04ep11-series07ep03-series02ep17…) when selected. I contacted the dev and they had no answer. Kodi standalone playing shuffle worked okay.
I’m too lazy to create my own build but luckily by chance I did a recent backup of KODI 20.5 with Burst 1.1 so I reverted back to that. Hopefully the next free version will be corrected.
Omega …. Diggz 3.0 RD or DIGGZ 2 (1.1) RD ? Which is superior … someone help… Many Thanks!
I prefer the Xexon Debrid Only 3.0. I won’t call it superior but i like the layout better. Im used to this set up in previous builds.
Both are available with a click of a button. If you don’t like one you can try the other. You may like Xenon2 better.
I would suggest setting up a Kodi Fork then loading 3.0 on one Kodi and the 2 1.1 on the other. That way you can decide for yourself which one you prefer. Have a great day.
Can you have more than one fork installed?
If so, what is the repo url to install Dings Xenon Debris Only 3.0?
If not, how would I update Xenon Plus running on 20.3?
TIA!
You need to have Kodi 21 or a 21 fork to run the new Diggz Xenon 3.0 build and the Omega Chef Wizard.
I think Miki answered your other question.
Installed the 3.o omega free version non debrid works good… downloaded scrubs,black lighting Fido and asguard and in settings disabled all the debrid so when searching in these add ons server does not freeze and make you reboot if a debrid movie is selected.
I am using Xenon free 3-0 after trying to open it it constantly goes back to the home page about 10 times already any idea how to fix this? Thx
What version of kodi are you using? When is the last time you updated?
Diggz has moved all of his builds to an AIO (all in one) build. The old build may have stopped working but not sure.
Its recommended to use kodi 21.1. Or at least 21.
The latest omega and i loaded Xenon free 3.0 from AIO
Have you tried to update to the new build?
Ok just saw the edited version.
Let me see if i can replicate on .y end
Is there a newer build than what is in AIO? I thought that is the latest and as i said i have loaded Xenon free 3.0 from AIO that is what i have problem with.
I am confused why you call it Xenon Free 3.0. The one in AIO is called Xenon FREE.
