Diggz Xenon. Coalition with Trakt not working
How can I ditch Coalition? or use another service like FEN or SEREN?
Selecting a Movie or Tv Show get ZERO results.
I have Real-Debrib, 300Mbps and a clean install.
Searched Diggz Forum. Posted. No results.
Thanks in advance…
-N
I am also using Diggz Xenon and Coalition is working with my trakt account. You may want to make sure you are logged in to Trakt.
Also, using this build may be new to you but if you look at the bottom of the Movies section there are other addons you can choose from. You may need to download the addon but the icon is there for easy finding. If you want to use other addons you will need to add them yourself.
Coalition is the default addon for the movies listed at the top. Not the only one you can use.
Also, make sure are logged into Real Debrid. Getting zero results is not common unless the movie isnt put yet.
Double checking everything now. Thank you JPM69.
No problem. Good luck.
Also, make sure you Re-sync your debrid and Trakt accounts.
Under Xenon Plus menu:
-Go to Debrid+Trakt Login (at the bottom)
-select Trakt and Debrid Account Manager
-Here you can Authorize, Re-sync and view your accouts
Coalition is new to Diggz and even if you updated from am older version your account may not be associated with the new addon. This may be why you are having the problem. The other addons may have carried over from the previous diggz build.
3 TVs. All KODI with Xenon Plus 2.0
Only the 1 Firestick and 2 ONN 4K.
Only one O.NN has the issue.
I wish the MOVIES section default was not Coalition.
Debrid nad Trakt is Authorized and Synched. I Checked accounts.
Will try a a few things like clear cache, fresh install.
Wondering if the D/L was bad? No CRC issues.
This ONN is using KODI on a SanDisk ULTRA 32GB USB 3.0
Checks out ine with MINI Tool Part Wizard.
I tested the USB hub on the other setups. Works fine.
ONN OS was reset to factory and upgraded. Kodi is fresh.
Stumped.
Going to re-install all with out hub and no USB.
In the words of the poet: " Shhhhh. Be wery wery quiet. I am going to catch that wascally wabbit!"
-E. Fudd 1954
This is a odd problem. Thanks for the advice.
No problem. I am actually getting my Onn delivered tomorrow and i will set up with Xenon 2.0.
I will let you how it goes. Seems odd that it works on the others but not the Onn. But thats above my pay grade.
For the price you will be happy with the new ONN. Fairly quick response times. Picture is same as FS…maybe a tad better.
Out of box setup takes a bit of time with update and google. The Your Apps part can seem long (Prime, Apple+. MGM, Netfilx etc). I have learned to add Amazon Prime Video after a full install otherwise it takes about 15 to 20 minutes extra.(meaning bypass that step)
The factory reset screen (push and hold button next to HDMI during boot up) is kinda nifty.
Wifi imho is better than FS 4K Max. Better speed when testing using Ookla (same servers) with Surfshark on (same locations) or off.
Thanks for the help.
-N
Well i set up my Onn with Kodi and Diggz Xenon 2.0 and my debrid and Trakt are working with the Coalition addon.
You might want to try to have kodi on internal storage if you are still having the problem. Troy mentions it runs better in internal storage in one of his videos.
So far I am impressed with the Onn.
Was able to load kodi with a build, HBO Max, Amazon Video and some free TV apps and still have 2.1 GBs left over.
I also deleted anything preloaded that I could that i dont use.
For under $20 its seems better than an Ad and app bloated FS. Time will tell.
Great news.
Happy for you.
I get asked to bring one of my ONN’s to friends’ house for a Sunday ballgame.
More reliable than the FS to move around.
BTW…I figured out part of my problem w/ Coalition.
I was dummy not to see this…
At some point I moved SurfShark to USB (and a few other things too)
All working now.
I still wish Coalition was not the only scrapper Trakt uses for saved programs/movies.
Thank you and Enjoy you New ONN 4K.
-N
Glad it worked out for you.
Just so you know, my Trakt saves movies not watched by Coalition. I just tested to make sure and i played a movie on Umbrella and it was saved to Trakt.
So Coalition isn’t your only option. Or shouldn’t be.
Hey Nonya…
Just a heads up. The new Diggz Xenon 2.1 allows you to pick a addon to pull your movies tv and trakt.
If you decide to update, go to Xenon Flavors at the bottom of Xenon tab and you can select Coalition, Seren, Fen Umbrella or POV.
I havent tried it yet but it looks like this is what you wanted.
Good luck.
Is coalition a Trakt based add-on? I’ve got RD and AD and can’t get anything to play through it.
Are you using Xenon Plus 2.3 (now) build?
If so, as long as you are logged into RD and Trakt they will work together with Coalition.
If you use the Coalition only “Flavor” set up, it will still work. However, I noticed that the trakt tabs wont show tv/movies you watched in other addons. But they should still be part of your trakt account.
