Diggz Xenon Build is Back and Updated
Diggz Xenon Plus was just updated to version 7.7 and is now working great again! This build was offline for a few days being updated by its developers.
What is the adult password for the xenon build?
Thanks for letting us know it was alive again. I was trying to use this about the time it had problems. Was pulling my hair out thinking about what i did wrong.Should of visited here a day or two earlier. i’d still have hair.LMAO. :v:
Seems like it is still down as at Sat 26 Feb?
Anyone else had success?
I installed it and it’s great! Maybe if you have an older build of it, from when it last worked, you might want to do a fresh install!! If you follow the guide above it steps it out for you and real easy to understand! The guide also starts off with recommending a reset of Kodi first and then using a fresh install of the build!!
:wink:
Is this a good build for a firecube or is it too bloated
69
69(just this number)
As of 11 Jan 2023 I can’t find any of the Diggz links working. I updated my Kodi to 19.4 the other day and when I went in to reinstall Diggz link I get the “Cannot connect” message. Before you tell me that I put the link in wrong. I did it via cut and paste and none of the links work.
So now what is person to do?
Yeah m8 it works too🤩
Very cool update. Super user friendly to setup…impressive.
It’s gone up a notch it’s 3.1 now
Looking for the best kodi build with iptv free or pay subscription.I Want live tv as well is movies and tvshows. I have premiumize but I want a good live tv to go with it without buffering.i know here there is no advertisement on pay IPTV
I used to use iptv on Kodi many years ago and Kodi is just not built to handle iptv imo. You will have a much better experience with a player like Tivimate and paid iptv sub. Free iptv streams are not that reliable tbh.
I agree with @Avid08 that kodi is not really built for paid iptv services.
However, did you try the Diggz Xenon build (currently version 4.1)? Since you are asking in this topic I wasnt sure of you had yet.
The build has a very good “TV Guide” section that can be used with lots of options. Of course the availability will depend on the addon developer not the build. Currently it offers addons such as Daddy Live and Dream TV and a few others. You can also set up a PVR for a tv guide type of view.
Also, not sure why you think paid IPTV doesn’t have ads? That may be true for PPV movies and shows but Live tv will have the same ads as the channel that is showing them (except some sports broadcasts).
Thank for the info what iptv service can I add to tivimate cause I only have internet
It depends on your specific needs and what local channels you need. There is the cheaper Chinese market place services or the private invite services. The private ones can be triple the price or more compared to the Chinese market place service but they are better curated and the EPG’s are usually better and you don’t need to curate them yourself with iptveditor or iptvboss
They can’t be spoken about on this open forum but you can in the patron section of the forum as you will know. Loads of info on some Discord channels and more openly spoken about. Lots of iptv subreddits got shutdown so most have moved to Discord.
