Diggz Repository Wont connect
So when i click the Diggz repository it says could not connect repository. It installed and everything so im not sure whats going on.
Start completely over and try again following step by step instructions from Troypoint. I know you did that already since 2 days ago and all, but just try it again and again is usually the fix.
After switching vpn multiple times the repo wont load…the app loaded from zip ok but faults with program
You were able to install the Zip file but not install from the repository? So the repository is listed and when you click to install nothing happens? Did you check to see if Chef Wizard is in your program addon section?
Did you allow “from unknown sources”? Although I dont think it would download zip if you didnt.
Not sure what you are downloading onto but do you have enough memory etc?
Diggz installed for me on the NvS. Lots of updates just as troy pointed out. Seems it uses too many resources or the surfshark shuts it down via kill switch. I uninstalled it and went back to just crew/seren & Reauthorized RD
