Diggz Plus Xenon 8.4.2
Has the Mad Titan Sports Addon been restricted? Is there a way to get the all the links to play.
Not sure what you mean by “restricted” . As for links they are hit or miss across the board with all addons . Good luck
The format for mad Titan sports
has changed and none of the sports links are playing
Do you have the JetProxy addon installed and enabled? that addon works in conjunction with mad titan sports. If not then install it. It’s located inside the Magnetic repo
Yes but it has requires an update. After updating Jet Proxy one or more items failed to play message continues to appear. I will try to reinstall the Jet Proxy addon
Still no luck after reinstalling the Jet Proxy addon
Diggz Xenon Plus Mad Titan Addon menu appears to have been reformatted and most are working well or under construction…!
It’s working for me. I did find this online while doing a search
