I continue to get a no connect notice when I try to load my Diggz Repository. I have followed all the proper steps. Have Kodi 20.1 loaded on several TV’s. Zip file loads but repository message “Can Not Connect”. Have reset and reloaded the TV
, Cleared the Cache on the T V and moved all movable apps to USB drive. Any suggestions. Use Diggz1 download. Would appreciate some suggestions. Thanks in advance.
kodi often does NOT like to be moved to a usb drive
also, make sure your VPN is ON when trying to access the Diggz repo
finally, it goes offline frequently so look for the latest url for his repo to make sure you have the current one
I had the same trouble. I tried it on Kodi Fork 2.01 and it works.
Thanks will try that
