Diggz AIO Ver 1.2 Crash/problems
Its been a while since i uploaded the build but ill try from memory.
Did you click on the box that says updates needed? It should take you to a sceen where you can see what addons need updates and select “update all”.
If you did that and all the updates are done (0) you go to the next step.
