I have tried for 3 days to update the Diggz AIO V4.0 . I kept getting a wizard error. I did a clean install of Kodi and tried to install the repo. With the official Diggz repo, it wouldn’t even let me add it in File manager. I used the tinyurl one and it took. Got the file unzipped and int repository and was able to install the wizard. That’s where it all stopped. When I clicked on the Diggz. AIO build I get nothing. I have tried this uninstall and fresh install several times with no luck.
Anyone have this same problem with a fix?
Never mind…I thought, let me turn off Surfshark VPN and VIOLA. Works great .Hope this info helps others.
Did the same thing. It’s Surfshark 90% of the time it seems now lol
I had updated without issues but then i found out that Trakt cant be authorized woth Account Manager anymore. Or at least for now.
My original update had the old steps for debrid/trakt logins.
The new steps have you authorize Trakt last outside of AM. But i had to fresh install kodi in order to get the new steps.
Yiu will probably get a "need to authorize Trakt message " ever 15 mins or so of you authorized the old way.
Just a heads up in case you get the message.
