I have the diggs matris build downloaded, for the past week when I try to open the chef matrix wizard I keep getting a chef wizard error and it’s says check the log?
Hi @spider1
Welcome to the community.
This kinda sounds like a input error.
I might suggest going back and review the install tutorial and pause it at each place where input is required to ensure correct spelling and all info is correctly input before moving on.
Just my suggestion.
Hey thanks, it would have to be a build error as it worked fine before the last update, since then instead of opening the wizard sends the error message.
I had tons of problems with kodi. Could never get a build to work right. Finally installed an older version without a build, just the addons I wanted. Works a lot better
