I’m having issues when typing in the search areas , I’m not getting titles etc showing up. I wondered if my xenon plus was not updated, currently I’m on 8.3
Thank you
I believe the latest version is 8.5. But it maybe different than the old version. hope this helps
Current version of Diggz Xenon is 8.6.3
You need to update the build.
I have 8.6 3 asThursday Sept 29th
Thank you very much, I will update
As of now none of Sports addons will play nfl replays
You’re welcome. Xenon is one of the few builds that constantly updates so keep your eye out for updates . Good luck
Thanks. I’ll look for the update
Hmm the new diggs xenon version i installed is 18.6.3
Unfortunately it is stalling when I startup my Kodi 19.4
Not sure if the new version is causing this
The skin comes up but virtually no loading of the programs ?
You might Do a fresh install of Kodi and Xenon. They work well together. Unless your device is low on resources. then it will struggle to run. Clear your cache. Hope this helps
