Just started having a problem logging in to stremio. It wasnt pulling in much of anything in “Discover” and was giving errors on some genres, so I figure, log out, log back in again and good to go. But I keep getting the same error when trying to log in: “Failed to Fetch. Error 500”.
I should note this is with the Windows version on my PC. I’ve uninstalled and re-installed but to no avail.
Any ideas?
This is the Windows app I use & it seems to work fine on the puter…
Yep, that’s the one I’m using Stremio 4.4 beta.
Roger that…I’m too new with Stremio to have much insight…maybe Miki or Dracoo will have a clue.
@sktn77a
That almost looks like something is blocking it from working properly. Are you on windows or mac os? There is a few things we can do.
Is this for evey show and movie? Another issue is you dont have the addon installed, or just need to reinstall it.
Well, I restored my Windows 10 PC to last week and that cured the problem. I hope it wasn’t an incompatibility with a Windows update!
