This morning I turned on my fire stick HD 4K and everything was wiped out I had to start all over again. When I went to my Fire TV I don’t have the option for developer options. So I’m needing help finding out what to do. I also would like to have your rabbit installer instructions. Thank you
Hi. I think if select about then press the enter button 7 time’s I think the developer option will be shown
That worked, thank you
RAI is Rapid App Installer. In the downloader app enter troypoint.com/tpapp and click go. Follow the on screen prompts.
Have fun and STREAM ON.
