Does anyone know how to delete Nuvio accounts. I had Nuvio working great until I installed a new addon and then the problems started . Would not sync, would not play any streams. So then I created another account and had all kinds of problems. Like as if both accounts were integrating with each other and nothing would work properly as far as streams. After much confusion and trying to to do many things like reinstall and clear queues and restarting, deleteing all cache on PC and Nvidia and restarting PC and Nvidia. Nothing worked. The only thing I think would work now is to delete the accounts under Nuvio.
I haven’t used it in many days and don’t plan on using Nuvio going forward. Just logged in on windows and don’t see any way to delete the account. You can sign out though
Join the Discord group and see if you can get help. Nuvio worked flawlessly for me while Stremio was having issues.
