Delete Device from Tivimate
Is there a way to delete a device from Tivimate?
@nettie14
Using the tivimate companion app I believe.
Thank You. I was trying to do it from the app
@nettie14
In the app there should be a delete icon beside each device listed.
There is. It’s the garbage can.
I have a few different boxes and companion works well on some of them but wont load on others. The boxes I use regularly I have kept on there and the ones I dont I have deleted them with companion I think the max is 5 units.
